Well i guess nobody is really interested in this idea. It suprises me because I figured there would be more people out there looking to have some decent bass in their truck without spend alot of cash and loosing storage space. Either way i think ive come up with the perfect, low budget bass upgrade.
1. Rear speakers are pretty much useless. They dont do alot for sound quality and they are pointed in a bad direction.
2. Bass isnt directional which is why subwoofers can be behind/under seat..etc. This makes the mounting position in the rear door perfect to hold subwoofers. The only problem is that the number of companies that makes good 6.5" subwoofers is limited, especially those that will work in infinite baffle configurations and be less than 4" deep.
3. After researching almost every speaker option I came up with the 2 that are the most feasible. The Elemental Designs 7kv.2/eu-700. This pro's are it is said to work great in Infinite baffle and can handle upwards of 150rms watts. It is a quality speaker, can be either single or dual voice coil and only has a mounting depth of 3.5". The cons are that the mounting flange wont bolt right up, they are heavyand they are worth $50-$65 per speaker. This brings me to my next option. The speaker is the tang band w6-1139si
http://www.tb-speaker.com/detail/1230_04/w6-1139si.htm
The speaker is a no-frills purpose built subwoofer. The pro's are that is $30 per speaker from partsexpress.com, the flange bolts right up and it is said to outperform the 7kv.2. The cons are it cant handle as much rms wattage as the kv7.2, isnt as great in infinite baffle and has a 4" mounting depth which is very close to the max for the rear door and may require a slight spacer.
4. With any IB subwoofer in a door sound deadening is a must, If anybody was ambitious they could probably built some kind of enclosure the increase the performance of both woofers. Depending on the budget either one will be a huge improvement on a stock system.
5. Cost Comparison
(All totals are examples of Highest and Lowest Possibilities)
JL Stealthbox $500-600 (Loss of centre console)
Amp $150-250
Total $650-850
Q Logic $150-$250 (Loss of rear storage)
2x8" Subs $75 - $200
Amp $150-$250
Total $375-$700
Rear Door $ Free (Loss of rear speakers)
2x6.5 Subs $50-$100
Amp $150-$250
Total $200-$350
Obviously other costs include wiring, sound deadening...etc but it is pretty constant for all three option.
I have not tried any of these option nor have i heard the results. It goes without saying that the stealthbox and qlogic will have more output and perhaps a cleaner sound. The problem i have with those options is first off the price and secondly the loss of storage. I dont want earth shatter bass but i want to be able to enjoy my music. Im going to try the rear door setup with 2 Tang Band woofers with an ???? amp sending each woofer 100rms watts. If they can take more might try more power but in infinite baffle i think 100 should be enough. Cheers
