Hi all,
I have a set of polyurethane bushings and steel bushings for stock 1st gen Tundra upper control arms. The kit is from Daystar and was $100 that included polyurethane bushings for the upper and lower control arms. I only used the lower control arm parts and was hoping someone is looking to just replace the squishy, stock rubber upper control arm bushings with some stiff/strong polyurethane bushings. The kit comes with instructions and all the necessary parts.
I lubed them with SuperLube, PTFE, Marine Grade Synthetic grease and they are awesome. Basically this kit allows you to press out your stock rubber bushings and replace them with stronger and longer lasting polyurethane bushings so you don't have to spend more money on a whole control arm to replace worn out stock bushings. Makes a huge difference in ride quality and strengthening up the front end. Also retains the Toyota stock upper control arm instead of questionable aftermarket OEM replacements from the auto store.
$25 willing to ship at buyers expense.
Cheers!
-Ryan
