I'm looking for measurements or actual drawnings for 2" spacer blocks to lift the front of my '07 Tundra. I'm going to make my own if I can get the proper sizes to cut. Any help with this would be great. THX
I made my own, but I dont remember what the dimensions were. If you are quick on the fly building them, then just remove the coilover and you can see what the footprint of the blocks need to be. Shouldnt take more than 2 hours to cut out the 2 plates, pipe, weld together and drill 4 holes (8 holes).
If you build something like this: Leveling Kit 2.jpg then you should only need some 1/4" plate, 3" Sch 40 pipe (2" might work). Dont try to round the edges, mine are square and it fits fine.
Also, I intended to only lift the front 2", but without good dimensions, I didnt know how tall the block needed to be. FYI, if you cut it at 2" it actually provides 2.5"-2.75" of lift.
I am contemplating taking mine off and cutting them down so that it only lifts 2".
