Which lift should i go with? Ive heard of people using both and both working.
H heinmillerlax · Registered Joined Dec 20, 2006 · 266 Posts Discussion Starter · #1 · Mar 14, 2007 Only show this user Which lift should i go with? Ive heard of people using both and both working.
J Jetes03tundra · Registered Joined Jan 22, 2006 · 1,955 Posts #2 · Mar 14, 2007 Only show this user both will work. Hockeyfreak has 2" cornfed spacer and trd aal and has 285's. Its all determined on what backspacing your wheels are. You will need ones with 4" or less.
shhendri · Registered Joined Apr 11, 2005 · 51 Posts #3 · Mar 14, 2007 Only show this user Both will work, just use a proper backspace on the wheel as mentioned above. If not you will rub on the UCA's, I've been there.
