This will definitely won't fit your 08 CM.... the wheels from the link above has 6 lugs and wrong bolt patterns!
:tu: What he said... you need a 5 x 150 bolt pattern and you need to find out what the offset is (most aftermarket rims seem to use a +35mm offset).
you could get hub centric spacers that change your bolt pattern. That way almost ANY rim would fit. Including these.
