I am trying to determine what parts are interchangeable between a 2002 SR5 2WD automatic 4.7L V8 Iforce engine and a 2000 Limited 4WD automatic 4.7 LV8 engine. Can I stake the engine from my wrecked low mileage 2002 and put it in the high mileage 2000?
the 00-02 tundras are essentially the same truck except that the 2wd has a A340E trans and the 4wd has a A340F trans. but they both should bolt up the 4.7. im just not sure about anything to do with the swap.
yes.. you will have to leave to trans in the 4wd and 2wd. the motor though is the same and should swap pretty easy.
i went the other way and it was pretty simple. i made my 03 tundra 2wd a 4wd with the trans from a 2002. this did require alot of extra parts along with the trans but it was actually pretty easy.
