I have read the posts about the "ECU" for this particular model truck as to where they are positioned. I have checked this truck out, and I could only find the white plastic looking box, as mentioned, wrapped in electrical tape, I took it off, and there is nothing behind it except firewall insulation. I checked on the steering column, and under the center console, but I don't find the ECU. Any ideas where else it could be positioned?
The Tire Guy
It's behind the glove box, under the cross bar.
The Tire Guy
You'll have to take the glove box out and there is a plastic cover that needs to be removed too, I think all you need is a phillips and 10mm. If you need a picture diagram go to Unichip's website and select our year model then select the install directions(pdf), that will walk you through the whole process.
