Going to start by checking fuses. Is it normal for these three items to just fail simultaneously?
My cruise control works when i set. The resume function which is up on the lever does not.
My brights work if I pull back on the lever but the on position does not turn them on.
I have a button below the steering column to the left that toggles the fog lamps on. It does not work at all.
This is on a 2000 Tundra SR5
Discussion Starter · #2 ·
For anyone wanting to know how this got fixed. I replaced the brake light bulb, the license plate bulbs and the cargo lamp. Along with the wiring harness for the passenger side rear 3 light assembly (brake, reverse, blinker) I suspect it was the brake light bulb causing the issue. Once that was in place everything resumed functioning as normal. No fuses were replaced.
