I just finished replacing the head unit of the 6-speaker 2000 Tundra Limited stereo with a Sony MEX-BT2700 bluetooth stereo, utilizing the built-in OEM amplifier. As it took a while to figure out the wiring from a variety of sources (primary http://www.tundrasolutions.com/forums/garage/faqs/audio/audiofaqmain.htm), I thought I would post it here for other's reference, in the attached pdf.
Information on removing the old stereo can be found on this Tundra Solutions article http://www.tundrasolutions.com/forums/garage/StereoRemoval.htm
Note, the Sony has bolt holes on the side that allow the use of the built in stereo bracket that holds the original stereo, also if you install the Sony head unit without the supplied bezel, you do not need to trim the dashboard. You will need a blank or a dash kit like the one from Carxtc found on Amazon.
