First step was to see if a 10" sub would fit. I thought it would after taking some measurements.
Next step was to evaluate the existing storage compartment.
I sealed it best I could using Peel & Seal tape from Home Depot. It's not perfect by any means, but it's a first attempt. This acts as a sound deadening material like Dynamat.
I put the carpet back in and removed the plastic frame.
I made the baffle out of 5/8" MDF. The rubber hose will act like a grille, allowing the sub to mover without it hitting the bottom of the seat. The MDF was primed, painted, and ultimately covered with spray on truck bedliner (as well as the hose).
Coated with spray on truck bedliner
You can see the difference in height between the hose and the sub.
Here it is in place, but not screwed down. I added the peel & seal to the underside of the baffle and added a rubber weatherseal around the perimeter to help with a seal and vibration.
I will add polyfill to the storage compartment before I screw it in place.
I'm having my Amp, wiring kit, and new head unit install next week, so I'll update the thread regarding performance. It may not sound good. I'm not sure. I've found several of these installs on the internet and they say it sounds nice. We'll see. Thanks for reading.
****Attached image is a custom fiberglass baffle that got me inspired to do this myself.****
