I have a 2000 toyota tundra SR5 V6 I Just replaced timing belt and water pump. New spark plugs in all cylinders and plug wires on cylinders 2,4 and 6. started up fine drove 200 miles washed engine started truck next day to warm up started ran for 5 mins then just shut off. truck cranks over and fires but dies immediately. Code pops up P1300.swapped 3 coil packs to different cylinder to see if i can isolate the problem, installed new cam position sensor, new crank position sensor confirm fuel pressure & electrical spark Checked all vac hoses and electrical wires and plugs let motor dry out for three days any help would be great thanks.
