I have a 2001 Toyota Highlander V4 that has lost operation of both rear power windows at several months interval. Neither master nor door switch works. I can hear a click in either door whenever I push the power window control to lower the window but that is all that happens. I have checked the fuses and they are both good. It seems odd that both motors would die at the same time.
Anyone seen this problem or have a suggestion as to how to diagnose this situation?
if you here a click then theres no issues with the fuses or wiring. do the windows get used often or do they hardly see use. if thats the case then they could just be getting hung up once in a while. you could take the panel off and watch them and see if they move smoothly, if you get get them to go up or down.
