Hello,
This is my first post. I own a 2001 Toyota Sequoia with 217,000 miles in great condition. The other day, when a snow storm hit, I went to use my 4WD and it would not engage. So I decided to look into it further. I saw a post that said to spray the actuator with WD40 and give it a slight tap. I did this with no luck, as the 4WD will still not engage. I then decided to check the fuses, as it is a 13 year old vehicle. Every fuse looked almost brand new so i knew this couldn't be the problem. The VSC OFF, VSC TRAC, Emergency brake, and ABS lights are also on in the front. I was wondering if any of you happened to have some ideas on what the problem could be. Any advice is highly appreciated. Thank You
My 2002 is slow to engage when it is -10 degrees and even harder to disengage...the orange differential light blinks. But it does work. The VSC/Trac lights on the other hand are not uncommon. There are threads here that can tell you more accurately than I can. It's one of the common problems and potentially an expensive fix, though it should not affect your 4wd.
I recently tried to shift my 2004 into 4 wheel drive by pushing the 4WD switch. The indicator light flashes green and the 4 4WD lights illuminate. When trying to switch back to 2WD, the indicator light continues to flash green, and the 4 4WD lights go out.
