How do I reset the alarm system on a 2001 toyota tundra without a remote. I used my key to unlock the door on my 2001 toyota tundra when I opened the door the alarm went off. I put the key in the ignition turned to the on position then turned it back to acc position & the alarm went off but the truck still wouldn't start. I opened the door & the alarm went off again. So I tried this several times with the same result. Can someone please help?
That seems strange? I only have one remote, which I use. My wife just uses a key and the alarm has never acted like that. Try disconnecting the battery, remove both cables. Use a jumper wire between the two cable ends to completely drain the system of any residual power. Let it set like that for about ten minutes. Then re-connect and see if that solves the problem. This is the method also used to re-set the computer and clear codes. Just may work with the alarm system??? Worth a try... Chap
