Hi all,
The A/C light was flashing, and the clutch is not engaging. I read on the thread here to jump wire the clutch and see if it engages.
I put a wire from the battery to the white wire, and it worked fine. Blowing cold air with light flashing.
I checked the 10amp fuse and it was good.
Does this mean the compressor is fine? Also, the refrigerant level is good.
What else I should be checking?
Thank you
I’m not sure what the flashing light means, but be sure to check the pressure switches
Yeah I just don’t know what it means when it flashes besides the obvious “It’s not working”. And there should be a high pressure switch and a low pressure switch. If either of those fails it’ll cause the ac to not work properly or not work at all
