2002 limited sequoia, outside air temp sensor is about 20 degrees off (low) today in Phoenix. It's about 109 out, sensor says 89 degrees. Always been accurate before. Washed car today in driveway, any ideas on problem?
No idea where sensor is located to check it.
I would suspect the outside temp sensor on the '02 is located in the same location as my '01. See attached pic of my 2001. This is a pic of the front of the radiator when I pop the hood. The sensor is located just above the top of the fan housing between 12 oclock and 1 oclock.
