I've got an 03 Sequoia (same interior as 04-06 DC tundra) that has a very irritating rattle that happens when driving between 1600 rpm and 2000 rpm. It sounds like a high pitched, tinny, almost audio feedback kind of sound. It seems to be coming from inside the dash behind the radio.
Any ideas? This is driving me crazy
I had a Honda pilot with a similar sound and it turned out replacing an o-ring in the power steering fixed it. I don't recall anything like that in these trucks, though. Perhaps someone else will give some input. Did you give the dash a hard smack?
Tried smacking the dash a bit, and I took everything out of the glove compartment and center console but that didn't work :/
2005 Toyota Sequoia Limited
Checks the heat shields on the cats? Mine lost the screws and rattle on hard acceleration up hill only
If you have an after-market radio, someone might have been inside the dashboard and dislodged something. It's pretty easy to check to see. When I replaced mine, I didn't do a good job managing wires and had to go back in with zip ties and re-secure the wiring to fix some buzzing.
Had an irritating rattle a little while back on my 07. Ended up coming from the glove box area. I unhinged the glove box door to access the lower portion to the passenger air bag. If I remember right there is a bronze color bolt that is something like 12-14mm....that was loose and solved the rattle. Might be one if those bolts being loose to the airbag module.
Thriller
