I have a 2004 Sequoia 4x4 that has the "VSC TRAC" and "VSC OFF" light on all the time. No other lights are on. I have a FSM and shorted the OBDII connector at CG and Tc to read the code. The VSC TRAC light blinked an "11" C1310 code. This is a short/open circuit issue in the brake booster. I replaced the Brake booster. When I pulled the old booster out it had several ounces of brake fluid that had leaked from the master cylinder. I purchased a new master cylinder. Installed new booster and Master cylinder. bleed the brake lines, connected everything back.
Next I shorted Tc and CG on the OBDII. Start engine and Cleared the code by pressing the brake pedal 8 times within 5 seconds. The original "11" code was gone. Got a new code "53"from the blinking VSC Track light. Engine is starting easy but idling low. Will cut off I don't give it some gas at startup. I checked the vacuum lines and the booster. All ok.
The "53" code is "Malfunction in communication with ECM" This is either an issue with the "ECM" or "Translate ECU" or the connector between these two.
Need special equipment to trouble shoot. So I am stuck.
I can not calibrate the Yaw, deceleration, steering sensors until all codes are clear.
Any advice? Replace ECM?
