Hello everyone,
2004 Sequoia Limited 4x4 114,000 miles.
Bought used with the floor Vibration.
Problem:
Sequoia vibrates from the floor and partial steering when driving straight and slightly gets worse when turning left above apprx. 20mph. Goes away completely when turning right. You can hear and slightly feel it.
Replaced:
New tires balanced and aligned.
rims were put on different axles when tires replaced.
Front and rear diff fluid replaced.
Transfer case fluid replaced.
Transmission fluid replaced.
Both sides replaced:
Lower ball joints
Hubs and bearings.
Brake fluid bleed and flushed.
Lubed all Four Drive Shaft Unions.
Problem:
Replaced:
Lower ball joints
Hubs and bearings.
