Hello,
I have a 04' Tundra Base model. I am looking to mount a couple light bars in the valence in between the license plate and I wanted to use the fog light harness already provided for simplicity but I cannot locate the harness in the cab of the truck. Any ideas?
Many Lexus and Toyotas
The fog lights are powered from the FOG fuse and go through the FOG RELAY. You will want to power your lights from terminal #5 of the FOG relay not from the switch in the cab.
If you want to be able to turn them them on without having to have the headlights on you will need to either power the fog light switch directly instead of from the headlight switch or add a separate switch and relay for them.
