Hello all. Great forum here.
Had questions about rear end for 2004 Tundra 4wd w/o cab.
I'm planning on swapping out complete rear axle assembly and was searching for a replacement.
Here's are my questions...
4x4 vs 4x2 assemblies. Mine is a 3.91 ratio and wanted of course to find the same.
Can I use the same part whether it's from a 4x2 or 4x4? Also, what years are a compatible swap with my 2004?
Seems to me if the ratios are the same one can.
Thank you in advance.
Back ground vin# check (5tkbt44104s451600) checked out on northamericanmotoring.com vin decode.
If you're trying to find a complete swap without modifying the axle housing than you'll need to stick with 1st gen Tundra (00-06). Brake lines, shock mounts, exact width...etc
3.91 is the most common and you'll find it in just about every V8 Tundra out there.
