1 - 7 of 7 Posts
Let me start off by saying, I love my truck but I don't consider anything on the truck to be heavy duty enough to handle plowing. Especially the tranny and axles. If you want to plow, buy a $1000 sh*tbox to beat the crap out of.
What he said. I guess if you were going to just plowing your own driveway it might
be okay, but if you plan on doing regular plowing like parking lots or streets I wouldn't
do it. And not just with this truck, I wouldn't do it with any truck that I wanted to
keep for a while. I would go out and buy the sh*tbox he was talking about and use
that seasonally.
John
Resident Curmudgeon
I agree with the sh*tbox theory for anything out of the norm. I'm guessing you don't get much snow in K-ville. If you're talking about using it to make extra $$, go with the sh*tbox and not your primary rig. Years ago, I'd see some military guys w the small plow attached to their trucks, up in New Hampshire. They were doing grocery store lots, etc. It made me cringe.
I plow with mine. I have a 2000 Tundra v8 AC 4x4. I have a 500 foot long driveway and it handles it ok. I use a Snowsport HD plow that hooks into a front hitch. I did blow the tube from my tranny cooler inside the radiator around the same time as plowing. I'm not sure if the plowing caused it but I wouldn't be surprised. These trucks are by no means "heavy duty" as the posters above pointed out. Your better off not using your truck if it is your everyday vehicle.
We use them for plows at our car lot....we get a lot of snow and its quite a large yard, the plow runs all day with a good dump. It's also a company truck, so I can't say it gets used gently by any stretch.
I don't know the exact model, but it's a fisher and looks like that:
Fisher Engineering - Snow & Ice Control Equipment - Snowplow Models - HD Series
Seems pretty heavy for that truck, if it was my personal truck that was only used for driveways, I would probably go one lighter, but for the big lot it needs to be as big as possible. We've had it on a RC LB 04 Tundy, and now on a RC SB 07. Both V8 4x4's, of course. Plow gets put on for 3-4 months straight, and the truck plows continously if it's snowing and still drives around town in between for deliveries and such. Never had so much as a wimper from the trucks in 5+ years, not one issue whatsoever.
If it were mine, I would put lift spacers in the front, or some ballast in the box....ideally a combo of the 2. But with the work one we just slap it on and pin it. Rides a bit low in the front that way, but like I say....no problems at all from any component. I would assume we're exceeding whatever the front end is rated for, but it's nice to know it will handle it.
Discussion Starter #7
Many thanks for your comments / response. At first I had a friend tell me he doubts that it would do the job (a good sincere friend) But, I have been reading continuosly for a day or two and and everything I have read says go for it (similar to your response) once again its for 10 -15 residential drives +/- and maybe a small commercial lot 10,000 s/f max. So far Sno Way appears to be my best best.
1 - 7 of 7 Posts
