oops, sorry, i missed that it was 2wd.
not sure how the lsd would affect transmission shifting???
maybe someone else can chime in with an idea for you?
my 04 transmisison shifts very well. when it was new, it did a thing possibly similar to what you describe. mostly if i slowed down for a corner, it would hesitate slightly before it would catch when i reapplied the gas. it seemed like the torque converter wasn't locking up until the rpms went a little higher. the mechanics at the dealership "worked" on it several times and i think they adjusted something in the throttle sensors, but never could get them to tell me what they did. it still does this occasionally, but is much better now.
i had posted previously for anybody to post the procedure or repair manual entries for how the throttle sensors and step motor might affect the transmission shifting, but nobody ever replied. maybe there isn't any relationship and it's all done via ecu?
on older vehicles, there was an actually linkage between the throttle and transmission to help it know when to change gears for passing, etc. it actually affeced the pressure on the clutch packs somehow. my parents had to replace a transmission in a lincoln because the little grommet that held the shift-down rod to the throttle linkage broke and the transmission slipped. over a short distance like 20 miles or less, it fried the tranny when they tried to limp it home.
not sure why i shared that story, other then to mention there always used to a strong relationship between throttle position and transmission performance and i'm not sure how it's done on our trucks. if someone could explain that and post some repair manual info, it may help us both out.
