My 2004 tundra sr5 v8 has 172000 miles it started to surge at idle a few weeks ago and would die at times when in gear today it started to surge while moving at highway speeds then quit running check engine light is on and was coming on and off prior to this it turns over but wont start any ideas it has new fuel filter new plugs new air filter
Have you scanned it for the code/codes? Can you hear the fuel pump running when the key is turned to the on or start position?
Good luck.. Not much info to go on in your post. Get codes and check fuel pressure.
thanks sorry for the lack of info but i think you both are right on the money with fuel pressure i think this has a pressure regulator iam notsure but that could be the problem thank you so much ill let you guys know
thanks theres no sound from the tank when i turn on the ignition i ordered a fuel pump does any know were to get a code reader that wont break the bank
