Hello,
I had my front passenger window replaced a year ago and have never been able to reset the anti-pinch sensor. I've also seen this function called pinch protection or jam control.
The window rolls back down 1/2 way whenever I use the "1-touch" close function.
Does anyone know the procedure for resetting the pinch sensor? I found a previous thread where someone had the same problem back in 2007, but a procedure was never finalized.
I've tried the procedure mentioned in 2007 where you push the down button and hold it till the window goes all the way down, then continue holding it down for an extra ten seconds. Then let go and do the same going up, and when the window closes continue holding it up for an extra ten seconds. That did not work.
Any other ideas? Do I need a new regulator?
Thanks.
