Hi Tundra Solutions Nation -
First time caller, long time listener.
I have a 2005 tundra double cab with 240,000 miles, and she's just getting broken in.
I started noticing a vibration and upon doing some research found that it's the center support bearing.
It's less expensive for me to replace the entire drive shaft assembly with you joints and center support bearing, rather than bring it to a shop that will replace the 3U joints and center support bearing, or a shop that will replace the entire driveshaft.
In my research I am running into a consistency issue with the length of the driveshaft. I've had several online vendors assure me it will fit and after ordering one I found it short by about 5 1/2 to 6 inches.
I could order one from a Toyota dealership but that would cost me more than a local shop to install a driveshaft that they order.
Looking for a good and reliable source for driveshafts that's not at the top end of the price range, and also any information on how to determine which driveshafts out there are going to fit.
(I took a measuring tape to mine and it is 88 inches from the back flange to the front U-joint where the yoke attaches).
Thanks in advance!
Ron
Thanks in advance!
Ron
