1 - 20 of 59 Posts
First post! I am looking at this 2005 Tundra SR5 that's for sale at a local dealership. They are asking $10,990 for it. It has 130k miles. What I'm wondering about is the frame rust. The body shows no signs of rust, but it definitely has a considerable amount of frame rust and I'm just wondering what everyone's thoughts are in terms if it's worth cleaning up, and how. I've thought about how I'd do it and I think I'd try to wire wheel it as much as I could then figure out a way to spray used oil all over the frame. I'm wondering if the frame is too far gone to even consider repairing, not to mention all the bushings and whatnot that are held in with rusty bolts. I definitely don't want a nightmare on my hands.
I've attached some pictures for reference. What are your thoughts about price vs. frame condition and amount of work to repair?
My opinion, in looking at the photos is that it looks like primarily surface rust. Does this version of the Tundra have a partially boxed frame? If so, I would be concerned about what cannot be seen.
For the visible spots, I would wire wheel and use some sort of rust converting primer, like POR. Places that apply rust preventive coatings can spray something on the inside of the boxed sections.
Is that a hole rusted through the member in picture #4, near the lower shock mount? If it is, plan on replacing some parts.
  • Like
Reactions: shatto
It's questionable. The frame is obviously beyond surface rust with the first layer of metal flaking off. I had some areas like that on my truck which I was able to wire brush off, but I also had some areas where part of the structural welds broke off.
Luckily, it wasn't a critical part of the frame and there was still enough weld to not be concerned, but things like those are what I'd be leery of that you can only check out with a ball peen hammer.
That drain plug on the rear diff will most likely have to be torched to break the rust bond and the from CAM alignment hardware is obviously frozen.
Truthfully, unless they give you a good offer and are willing to let you or have them check the integrity of areas your concerned about, I'd start looking at other Tundras. JMO
Lastly, did you check for holes in the pickup bed? They may be there if there's a plastic liner present with them hiding underneath.
  • Like
Reactions: shatto and brhoton
I don't believe there are any fully boxed areas of the frame on the 1st gens. And now that you point that out I certainly am seeing the same thing you are. I cannot quite tell if there's a hole there or not. I will definitely go back and check on it and hopefully snap more pictures. The more I look at this thing I don't know if I want to deal with it for the price they're asking.
The diff plug and alignment cams are definitely concerning. And thank you for the tip on looking underneath the plastic in the bed. It in fact does have a plastic bed liner and I have not looked underneath it. I feel like this 11 y/o truck is not worth the $11k they're asking for it
My 2002 Colorado based Tundr looks much much better than that at 400,000 miles. That much rust is like... $2k worth off the price to me. The good thing is that the bushings and such probably will be fine (ish) for the next 100k miles so kick the can down the road. You could buy it and do nothing and sell it after you put 100k on it.
Correct me if I'm wrong but I thought the recall on Tundra frame only covered 2000-2003 Tundras? I've never been able to find info on 2004-2006 frame recalls.
When I bought my 2006 DC last year, it had an entirely new frame, brake lines and some other stuff. Guy even had the paperwork in the glovebox. The dealer should be able to pull up the VIN and see if it should have been taken care of. If it should have been and they sell it without it being done I would imagine it would be a legal issue.
my husband has an 06 tundra there was a recall regarding the frame being rusted about 1 yr ago. The dealership sprayed the entire frame with rut preventive/paint etc. He was told if it was too rusted the recall would replace the entire frame. Its worth running the vin and seeing if there is an open recall.
Oddly my 2003 Tundra is currently having the entire frame replaced. I waited 4 months for the frame to arrive. The 3.5 Billion settlement from last year may have something to do with it....
I have a 2002 SR5 I bought 2 years ago from the original owner in Pennsylvania. It only had 87,000 miles on it and got it for low asking price. as time has gone by I've noticed more rust issues and I'm being nickel and dimed on brake lines. Is Toyota replacing the frame under their short term recall notice from back in 2010 thatI just found out about? If so, then what can I do to get Toyota to do this for my Tundra?
Thanks for any input!
Hey guys.... two things... go to toyotaframesettlement.com for info on the frame debacle. My sequois rust is BANANAS and I can't wait to have my frame replaced as part of the settlement. Second thing... the images at the beginning of this thread... surface rust? really? What is heavy rust? When the frame cracks in half and you can see through it like swiss cheese? That frame is awful and this is coming from a guy who lives on the ocean.
Check out the site. Not a scam. On the 1st gen Sequoia I did a lengthy post of what this is all about. Expect official recall notifications from Toyota in the mail in the next 4 months or so.
I'll explain exactly what happened..... My spare tire suddenly broke off the undercarriage. Needing a new tire as I couldn't get it back from off the highway I went to several different local flat fix shops to purchase a rim and spare. The last one I visited said to me that I should go back to the dealer because there may have been a recall for the bracket. I had nothing to lose so I went to the local dealership here knowing that there was an airbag sensor recall that I had to take the vehicle in for.
Service Mg said that none of the recalls were done on the vehicle. We're going to do a full inspection. Result: we're requesting from Toyota a new frame. Was authorized within a few days of request. Frame came a little over 3 months later. Call from Dealer....Bring vehicle in. Frame has arrived. Vehicle completed Today.
Now. How can you get the same treatment???? I don't want to lie to you. I really don't know.....
Discussion Starter · #13 ·
Here is the picture of what looks like the hole in the frame behind the front control arm. It's not a hole. I I'm going to read up on the settlement to see what options I may have.
HTML:
Is this vehicle for sale from a local Toyota Dealership? I've never seen a new car dealership offer for sale a car of that age. Normally in my area of the Northeast late late model vehicles like that one are auctioned off...
You would need the Vin # of the vehicle and proceed to a Toyota Dealership Service Dept to find out if the vehicle was serviced for any campaigns issued. Take a look at the tire carrier underneath the rear bed. That was a popular area of safety concerns.
I personally would avoid this vehicle from what I see from your photos as well as based on the $$$$$$ price. Without the recall history your going at this blind. There is a definite Airbag sensor recall on that vehicle. Do you know if that recall was handled?
If you can't get a frame replacement, I would'nt touch it!
Even if you could get the cam adjustment bolts out, I doubt new adjustment bolts would even seat properly in the frame.
I just took the truck in to get new tires. started to put it up on the rack and the rear end sagged as soon as they started to lift it. I didn't get the tires. When I got home and crawled underneath I found the frame has buckled/cracked right underneath the back of the cab on both sides. (See Pictures).
I registered my VIN with Toyota a couple days ago. The only official service their site shows is the truck was looked at for a "check Engine" light. No indication of recall or inspection for frame rust despite it being in one of the 20 states that their inspection recall was for back in 2010.
I'm definitely contacting Toyota over this.
Question for ClutchCargo. Are you the original owner? I'm the second owner on this truck and I'm wondering if that will make a difference to their customer service for my vehicle?
By the way, thanks to ClutchCargo for responding to my previous inquiry.
No. I purchased it from the original owner. There are 3 pages of receipts. No out of pocket. Here the big one 176888 miles. Feels like new.
Thanks ClutchCargo for your reply.
I will let y'all know what progress I make as I deal with this issue. One more Question? What state do you live in? I'm in WV. I just wonder if it will make a difference from state to state?
Darn frustrating. My truck has a perfect body, clean under the hood, 101,087 miles and the frame is shot.
The Peoples Republic of Long Island New York
Discussion Starter · #20 ·
So I did a little investigative research for this truck on toyotaowners.com. It appears the airbag sensor was replaced per the recall on the truck, but last year around this time, the right front shock broke while the truck was in motion. So who knows what other damages could have taken place, although it doesn't list any damage in the repair order.
The truck spent the majority of its life in New York, which explains the rust problem. Also there is a lull in service record from 2008 to 2013 when it arrived in Nebraska. It just had a multi point inspection April 7, 2016 at my local Toyota dealer and says nothing towards a new frame or frame repair. So I wonder if there's any further action I could take to see if this frame is eligible for repair? Keep in mind I do not own the truck.
1 - 20 of 59 Posts
