1 - 8 of 8 Posts
Does anyone else have any experience with this problem? My 2005 Tundra surges at a steady throttle. There are no fault codes (check engine light never came on). Any thoughts? I replaced the mass air flow sensor with no luck...
While driving on the highway at normal speed, the engine will "lose power"/surge but only for a split second. Just enough to feel it in the seat. No RPM or speed change. It's that quick but it's constantly doing it.
Discussion Starter #5
No, it shifts fine and the torque converter locks up fine on the highway. It seems like a vacuum issue or sensor issue...
Check spark plugs and coils. It could be carbon tracking if a plug is cracked.
Sent from my iPad using Tapatalk
Is your AC on while this happens?
1 - 8 of 8 Posts
