I have a 2006 4 door Tundra XSP with the A750E transmission. Yesterday on my way to work the check engine light came on, after sitting all day the light was off on my return trip home, approx. 11 miles. When I got home as I pulled in the light came back on and the transmission did the jump scenario that I have seen mentioned as if someone had just rear ended you.
On my way to work today it began to slip and then reengage rather violently a few times. After connecting a scan tool to it we found the code P0986 Shift Solenoid "E" Control Circuit High. Checked and cleaned the 15 pin connector and checked resistance of the solenoid. 1st check revealed an infinity to ground. Checked later and the circuit was within the 11- 15 ohm range. Also checked the circuit from the ECM to the female 15 pin connector and the continuity was good.
I decided to take it for a quick test drive and it resulted in the transmission slipping and reengaging harshly over and over again. I am Soldier stationed in Germany with no access to anyone who knows anything about a Toyota Truck. From what I have read the ECM should take over and turn off the SR solenoid to allow for continued safe operation, but I am not experiencing that. Can anyone provide any assistance at all? I would greatly appreciate any help or advice. This is my daily driver and I have no other way of getting to and from.
