I want to level my 2006 DC but I am not sure what size spacers I need. I did a search but cant find a clear answer. I was leaning towards the 1" Daystar kit but I would rather not have to take the top plate off to replace the studs and I cant find a 1" kit that just bolts to the original studs. I have found plenty of 2" spacers that don't require removing the top plate but I read that spacers actually lift the front by about 1.6 times the spacer size so 2" might be a little high in the front. Anyone with a leveled 2004-2006 DC have any advice?
I just completed leveling my 2006 Double Cab. Used supreme suspensions brand in-coil spacer. A 1.25" thick spacer will yield a 2" front lift. Placed a 1" block in the rear. Also installed the 2" diff drop to keep the CV axels close to factory. One month in and everything is fine.
