Hello, I’m hopeful someone can help me troubleshoot these catalytic converter codes so I can try to avoid throwing tons of money at the vehicle and not solving the problem. The vehicle has about 234k miles and the codes are for insufficient catalyst efficiency on each bank.
These first showed up after alternator failure mid family road trip. I should have pulled over and had the car towed but my wife did a quick Google search for the nearest shop and I chose to limp the car in about 2 or so miles. It was running really rough and backfiring so I was thinking the O2 sensors got fouled up and were the reason I was getting codes now. I went ahead and ordered all four sensors, but before installation I found a video on how to check your sensors with a multimeter. The old sensors get resistance readings (no “OL”/ open loop), so I’m not convinced I have bad sensors.
Reference video:
One other video I found was to put an infrared thermometer on the exhaust before and after the cat. If the cat is working properly, the exhaust pipe should be cooler upstream of the cat. I’m thinking I will buy a thermometer and check what I get.
Reference video:
In the meantime, I was wondering if anyone had been down this road before and could share what worked. hopefully the cats aren’t ruined because replacement OEM cats are super expensive!
Reference video:
Reference video:
