1 - 7 of 7 Posts
I installed Fogs lights upgraded to led 9600 bulbs to fog lights to factory harness installed fog relay at back of fuse box and upgraded factory stalk with fog switch, When I turn fog light switch on it only turns on High beam head lights and no power to fog lamps ,All parts are factory new, I also upgraded my head lights to led 9500 bulbs if that matters,Any one know why thanks in advance,
Fog lights shouldn't come on with Hi beams. They only work on low beams if that helps.
I did the fog light mod on my access cab and they come on whenever I want them.
I especially like them when using high beams.
The fog light mod is a lot easier on everything but the double cab imo.
I don't recall the details, but I think you have to install a relay.
There used to be a write up on the mod for DC.
I did mine through Vleds and they sent a relay I had to connect to my headlight to make my fogs work correctly.
1 - 7 of 7 Posts
