Hi everyone, I saw some old posts about this, but didn't see how anyone solved it.
I am having an issue where the engine has a hard time starting. It will crank strong, but seems like it is lacking or getting too much fuel. It cranks for 3-4 seconds and sputters then starts and runs just fine. It is not as much of a problem when doing a cold start in the morning, but seems worse when starting after has been driven, then shut off for 30 min - an hour.
All I know is that this is not normal and it is not a battery or starter issue.
I saw some old posts that suggested replacing the cold start injector, but the 2006's do not have one. Other posts suggest the coolant temperature sensor. Just wanted to see what worked for others? Thank you.
