Hi, as the title of this post says I need to change the plugs and the valve cover gaskets are leaking on my 06 Tundra. It has 130,000 miles and what I believe are the original plugs. What do you guys recommend?
Denso plugs. You may be able to just tighten the valve cover bolts they work loose about half of mine were finger tight. Spec is 53 INCH lbs so make sure they aren't over tightened whatever you do.
I’ll look on Denso website to try and find the correct part number.
The dealer said they snugged the valve cover down so I might as well get some gaskets while doing the plugs.
