See the sub setup done for me by SOS Perf(now tundraracing)
It's JL Audio 300/4 amp and 2 10W1 subs
Yahoo! Photos - 2007 Tundra 2 6 007
Rumbler
Rumbler
Nice setup. Are there pre-outs for the amp in the factory deck, so that you didn't have to change the deck out?
You might as well be speaking Greek to me, as I don't follow aftermarket stero stuff. Basically what I'd like to know is this...when I buy a new Tundra with the regular deck (not the NAV), and if I want to change out the speakers and an add amp and subs, can I do so and still keep the factory deck? If so, how? Basically, how does the amp hook up to the factory deck? I like everything to look as original as possible.No preamp outputs, but the JL amps have a very wide range input sensitivity so they can be driven with almost any speaker level output.
Rumbler
it was your truck, they should have checked it before if they were worried. You have every right to do what you want. I would have said F off and hung up lolI spliced in a line out converter on my 06. not doing that again. when I traded in my 06 i put everything back to normal but I guess theygo through the truck very thoughly when it's still under warrenty they call me two days later and asked me about the wires running to the factory amp with the shrink tube on it and were very pissed.
yes you can, and since you dont understand car audio, just ask someone who does to do it for you.(best bet)You might as well be speaking Greek to me, as I don't follow aftermarket stero stuff. Basically what I'd like to know is this...when I buy a new Tundra with the regular deck (not the NAV), and if I want to change out the speakers and an add amp and subs, can I do so and still keep the factory deck? If so, how? Basically, how does the amp hook up to the factory deck? I like everything to look as original as possible.
Thanks in advance for the info...
Please do not take offence to this....You might as well be speaking Greek to me, as I don't follow aftermarket stero stuff. Basically what I'd like to know is this...when I buy a new Tundra with the regular deck (not the NAV), and if I want to change out the speakers and an add amp and subs, can I do so and still keep the factory deck? If so, how? Basically, how does the amp hook up to the factory deck? I like everything to look as original as possible.
