So… I jump in my truck and the 4Lo light is flashing joined with the manic beeping that sounds like a McGyver bomb is about to blow. It won’t engage into drive or reverse (all neutrals) and if I put it into neutral and give it a moment I can hear the transfer case click out of 4Lo, the light goes off and all is good.
it was driven in 2wd when parked and will shift into all of the ranges as it should but for some reason it tries to shift itself into 4Lo anytime the key is turned off. It otherwise works as it should. No check engine light or codes.
Anyone else have this issue?
2008 DC limited 4wd 156k miles. 5.7.
I think you’re truck just wants some dirt! TRDs notorious chirp when turning are another indication of the same. Seriously, it sounds like something that’s in the settings in the truck’s preferences, likely only changed at a dealer Please let us all know how you remedy this, if you decide to.
