Rainy day project today, was to replace the radiator in my 2008 Tundra with the 5.7 with 130k miles. Everything went well and didn't take too long but those 2 lower bolts are a PITA to get to and back on. I used the OEM replacement right from the stealership. Got everything back together and started to slowly add coolant. It takes roughly 10-11 liters or just under 3 gallons. I was only able to add about 1.5 gallons before it got full.
So I started truck up, squeezed top hose for bubbles and got some out but level never dropped. Let it run for 15 mins with heat on. I saw temp gauge on dash climb up to just below midway. Top hose felt warm to touch as I squeezed it but level never dropped enough to add anymore coolant.
So my question is does anyone know if OEM radiators come with any plastic plugs or anything that should be removed prior to install? I didn't even look, I just installed and hooked up each hose. I am wonder if there could me some sort of plastic plugs in the inlet or outlet that I should have removed first prior to install? I attached a pic and I dont see anything obvious that would need to be removed on the new one?
The lower hose of my radiator that goes from the bottom of the radiator up to the thermostat never got warm after running for that long. Its either plugged radiator or bad thermostat? Would just be really big coincidence to have thermostat go bad when I wasn't having any issues with it prior. And water pump was replaced at the dealer at 85k or so due to a leak so I don't suspect that is an issue either.
I have since let motor cool and saw some drop in the funnel but nothing significant. Any ideas what to do next?
