Does anybody know the procedure on how to replace the
third brake light of 2009 avalon? No access from the trunk.
Looks like I have to remove the back panel. Any help is greatly
appreciated. Thank you. Lino
Hey Lino,
I just had to remove the third brake light in my wifes 06 Limited. It is a little time consuming to get to the brake light but if you are patient and mechanically inclined, you can do it. There is a post on some forum ( Google removing rear deck lid on Avalon ) that gives a pretty good discription on how to do it. I found a cold solder joint on the LED circuit board that is the brake light. I resoldered it and it works like a new one. Good luck!
