I plan to replace the fluid in my 2009 Tacoma manual transmission. Are there any issues that I need to be aware of. I assume that there is a drain plug and a fill plug.
Just make sure you can loosen the fill before you drain on any manual transmission, transfer case or diff. That way you are never stuck with no fluid and no way to fill in case of a stripped/frozen bolt.
