1 - 8 of 8 Posts
Driver of 2 Tundra trucks
I picked up a local 1-owner 2010 Camry LE the other day.
Very good condition with a few exterior beauty marks*
110K on the original drive-train.
It's pretty much a base vehicle, so I will be making a few practical upgrades.
1. I will replace the heavy steel 16" wheels with lighter OE Alloy rims. (DONE)
2. Sway bars, braces & bushings. (Shelved for now)
Does anyone have experience with Ultra Racing products?
Discussion Starter #2
Replacing the OE steel wheels with OE alloy wheels reduced the un-sprung weight by 3 pounds at each wheel.
We used the TPMS from the steel wheels, and they work 100%.
This is the UR rear sway bar that I am considering.
I de-badged (shaved) the trunk lid for a cleaner appearance.
I have put the UR bar upgrades on hold... the factory parts are fine.
I will replace the worn struts with new KYB Strut-Plus instead.
Discussion Starter #4 (Edited)
The R headlight lens is FUBAR.
No matter what I do, the lens clouds up pretty quick.
I ordered a replacement.
Did you know the front bumper cover has to be removed in order to replace a head light?
Discussion Starter #6
I had the KYB Strut-Plus installed today.
Easy installation, and excellent results.
I highly recommend this upgrade.
TRD makes great upgrade parts for Camery have you looked into that ? There's also a Camery TRD Edition it's a sick ride..
1 - 8 of 8 Posts
