Hello, did you ever figure out what the noise was? I have the same issue with my truck. I have replaced the belt in the past. The noise stopped for a food while but has returned once again. Belt still looks good. Please let me know your findings…So my Sequoia started making a noise after we drive it for a while. Link.
Any idea what could it be?
I have done 3 belts on my 08 since 2011 and 127K miles of owning it, 167K total. Each time they "Looked' good but still squealed at start-up and would settle down. As they progressively get worse they sound like the the video above, in my experience. It is a cheap each fix. Breaker bar and socket on the idler pulley. I suggest pulling the metal skid plate to get better access to route the belt. I have done it in the driveway with my wife holding the breaker bar. If that does not take care of it an idler pulley would be my next move and or looking at all the accessories, ie alternator, AC compressor, water pump, one of those could have the bearings going bad. Water pump will typically leak coolant when it is failing. pink crusty stuff down the front of the motor onto the skid plate. I also replaced my water pump at 109K miles. Waterpump Mine is starting to chirp again at start-up so I will be changing it again soon. Some vehicles can go 100K or more miles and the belt never makes a sound. I have replaced a couple on 12 Camry V6, 09 RAV4 I-4, purely because they hit 100k miles. I always save the old belt, throw it in with the spare or jack tools ect., someday it might save you on the side of the road.Hello, did you ever figure out what the noise was? I have the same issue with my truck. I have replaced the belt in the past. The noise stopped for a food while but has returned once again. Belt still looks good. Please let me know your findings…
thanks ahead
