New tundra owner here...... I lost my Tacoma that I had for 10 years to a red light runner. So I decided to go with a full size truck. Now that I have the truck I am having some issues. 1) changed plugs with oe iridium, check engine came on. 2) code scanner said miss fire cylinder 8 check engine came on again fairly soon. Miss fire cylinder 8 I also replaced all 8 coil packs with or Denso. The dreaded light came on again I have a 2013 tundra 4.6 and seem to using some antifreeze as well any ideas what to do next. Thanks
83 views, not a single welcome.. idk about this forum
-Is there any coolant in your oil?
-Cyl 8 plug, how does it look?
-If you can, have a leak down test done..
Good luck and welcome.
