1 - 8 of 8 Posts
Our battery died a few weeks back, and ever since we replaced it. There is a blinking "MAN." light on the dashboard.
I know it's for the height adjustment, but we ask the dealer if they knew what it meant, and they didn't know without keeping it overnight.
Just wondering if anyone knows that the blinking light means, and how I can possibly fix it. Is there some reset, or maybe a fuse??
I'm in a platinum and playing with the buttons right now to toggle or have the light blink.
Have you tired pushing the manual up/down button or the height control button to see if it coaxes it off?
Sent from my HTC One M9 using Tapatalk
Check for code(s)?
Discussion Starter #4
@surfnsteve, yeah I tried toggling it. but it just stays on "N" and the "MAN." keeps blinking.
@MtnClimber, i have not check the codes yet.
I keep reading the air suspension senors can go out. Just seems odd it happened whenever I replaced the battery, it was working before that.
Hi folks, I had to jump start my ride the other night and I am now too getting the height control MAN. indicator flashing. Really interest if someone had a solution... fuse?
Page 244 of our beloved manual says: "If there is a problem somewhere with the electronically modulated suspension, the height control MAN will behave as follows:
1. The indicator will not come one when engine switch is turned On and
2. The indicator will blink.
Although the vehicle may be driven, have the vehicle inspected by your Toyota dealer."
That is Toyota speak to indicate the problem can only be determined by specialized dealer or quality mechanic diagnosis equipment.
Just for kicks, have you tried reading the ODB2 port for stored or pending CEL codes? Might be one there you can reset....
Luck and enjoy those Toyotas. : ^ )))
1 - 8 of 8 Posts
