So I have a 2014 with 125k miles and it recently put up codes. I don’t have access to much without going to a actual shop and wanted to see if anyone knows the problem before I go spend money. I have a check engine light and traction control is off. When I used the free scanner at autozone it gave me the P0172 and P0175 code. Truck runs smooth except when I first start it. It’s like the truck is looking for the right fuel to air mixture for a few seconds so it will start up and the rpm will go around the 150-500 range then jump up to 1000 and work it’s way down to 750 then she works like she’s supposed to. Keep in mind all this happens in about 5-6 seconds. I don’t smell any gas around the truck at all and have used sea foam to hopefully clean the injectors. Any ideas?
