2014 Toyota Tundra 5.7 SR5 Texas Edition 2WD
Posting this so others in the future know that the Stainless Works Cat back touches the Rear sway bar. If you shut your door or make a turn the exhaust will bounce and ding off the sway bar. You can live with if it you don't mind the loud clink noise because the exhaust doesn't get hot enough in the rear to heat up the bolt or bushing. Other than the compatibility issue the exhaust is amazing.
153710
153711
