I have a 2014 Tundra Limited with stock 20 inch wheels. The stock offset from Toyota is +60mm. I am looking to replace my rims with 18 inch rims so I can add a little bit of meat to my tires without doing a lift. There aren't any aftermarket options for 60 offset and I haven't been able to get a straight/consistent answer from the different wheel dealers I've talked to about what will work on my truck. was told I could go as low as an 8 or 9 inch width tire with +30mm offset without causing any issued with rubbing, etc. The other one I spoke with told me I was ok to go as low as +18mm offset. I was hoping someone could offer some insight into this to help me out. Thanks in advance.
