Hope someone can add to this. I'm in a very similar situation looking to lift a 2016 Sequoia SE. I'd like to put 35x1350R20 tires on it.
Thoughts on the following?
3" OME front lift kit with shocks and coils
For the rear: Dobinsons 2" lift coils #c59-578 and Bilstein rear shock*33-187280
Vision Off-Road*Manic 20 X10 5-150.00 -25 BKGLMS
Nitto Ridge Grappler 35 /13.50R20 126Q F2 BSW
I'm also trying to put 35x12.5xR20 on my 2010 Sequoia. Now for the 12.5" wide I found this: Ready Lift 2008-17 2&4WD Toyota Sequoia 3" lift kit Product No: 69-5015 RL. Comes with:
- front strut extensions
- Rear coil spring spacers
- Front sway bar mount spacers
- Differenital drop spacers
- Rear shock extensions
- Skid plate spacers
That product states: Compatibility with a 4wd 2008-2017 Sequoia includes Tire Size: 35x12.50 tire on a 9" wheel with 6" of backspacing (+25)rims or 285/65/20 on 20x8.5 rims
I was hoping to use my current stock 20" rims to save money which I believe are 8" wide with a 60mm offset which I don't know if that would work with the above (can anyone help with this?)
Given you want to put 13.5 wide, I'm skeptical that you'll get them on there without rub. If you turn your wheels all the way to the left, then back it off a smidge and get out and look at your front left tire, you'll see that if you went to a 35" which is 1.5" longer on one side than the stock 32s, plus 13.5 wide, which the stock is 10.8 wide I believe, your right into the mud flaps. I know guys usually take those flaps off but still going to be tight. Then the width also poses the problem of rubbing the control arm from what I've been told. Guys at my local shop said they recommended a spacer. I'm new to this stuff so I hope I haven't given any misinformation and if so, apologies in advance.
*UPDATE*
Spoke to Ready Lift Tech Support. For my 12.5 inch tire, he said my stock 8" rims with 60mm backspacing will not work without rubbing unless I used a 1" wheel spacer. I also asked about 13.5" for you and he said that it would require significant trimming in the wheel well and a larger wheel spacer for sure or your not getting that on without rubbing. Now this is for the Ready Lift kit, not yours so there may be a difference. Hope this helps.
