I have searched and found a lot on tire sizes, lifts, etc. but wanted to know if anyone has this setup. I plan to do a 3/1 lift/level - probably the 5100s - but its time for new tires first... I have the factory 20s and want to get the tallest tire I can with the stock suspension, so when I do a small lift/level it will still look balanced. Has anyone installed 275/65/20 with a stock suspension? I have 275/60 on it right now and it *appears* that it would work, but its close to the UCA... just wondered if anybody knew for sure whether or not it would rub.
You won't have any issues. There's no difference in width, just height. And the tire is only 1" higher overall, which means the truck sits 1/2" higher... that's it. I ran them for a little while too... no issues.
Great! Thanks for the feedback guys! I'd rather know than buy then and find out that little bit creates a problem...
Looks like you had had fun in the mud TakEmBack.... Me thinks you need 4wd! (judging from your pictures!)
