1 - 7 of 7 Posts
Hey guys I know the tire size / leveling kit subject has been beat to death. But I have found a good deal on some BFG AT KO 275/75r18 tires and I need an alignment anyways, so I might as well put a leveling kit on. I did some research and searched on here till I was blue in the face. Since these are about a 34" tire, but only around 11" wide, will I get any rubbing with a 2.5 leveling kit? Why does everybody seem to stick to the standard 285 or 305 sizes? just for the width? any advantages to going with a wider tire? Lastly, does anybody happen to have this tire with pics of it on a 2007 or newer Tundra?
Those will fit...You might need a little trim on the skidplate and maybe a little shaping of the plastic in front of the tires but that size should be perfect. I ran 285/75/18 Toyo Open Country's on mine for a little bit. I actually miss that size. Basically the same size as those KO's you're looking at...Check em out below...
were those pics taken with your toytec leveling kit on the front?
Discussion Starter #5
also why do you miss the size? Did you go up or down?
Discussion Starter #6
sweet that looks awesome!
I miss that size because I stepped down to the 285/65/18 which is almost 33" diam. I miss that extra inch of diameter. But I do love my KO's too!
1 - 7 of 7 Posts
