I have 3 new 2010 Tundra 2WD SR5 Doublecab trucks... one's white with black interior. One's silver with black interior. One's black with gray interior. They all have, for options:
Package(s):
Accessories:
AA 18" Alloy Wheels
CK Cold Weather Package:
EJ JBL AM/FM/MP3 6-Disc Changer,
FE 50 State Emissions
HM Power Heated Outside Mirrors
KG Running Boards
PE Cloth Bucket Seats with Power
RL Daytime Running Lamps
SP SR5 Package:
WX Power Horizontal Sliding Rear Window
C4 Carpet Floor Mats
and MSRP is $32,891.
$28,297 after rebate ($2K) or use the 0% apr for up to 60 months in lieu of the rebate.
Reach me for this truck! 310 939 7801
Discussion Starter #2
Tundra Crew Max huge savings, 0% apr available too
I should also add this truck... mostly because it's SO well priced and not that common a truck anymore! And, with 0% apr for 60 months, I expect these trucks to sell PDQ!
2010 Tundra 2WD Crewmax 5.7 SR5 in silver with gray cloth.
Green items are standard, purple items are optional!
MECHANICAL & PERFORMANCE
5.7L iFORCE V8 DOHC 32V Dual Independent
VVT-i 381HP/401 lb-ft and ACIS
6-Spd Automatic Trans w/Sequential Shift
GVWR = 7000 lbs. Payload = 1665 lbs.
Max Tow Cap = 8400 lbs.
Engine Immobilizer, Cruise Control
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
4.10 Rear Differential w/10.5" Ring Gear
Automatic Limited Slip Diff (Auto LSD)
Coil Over Shock Double A-Arm Front Susp
Multi-Leaf Trapezoidal Rear Suspension
Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors
18" Steel w/P255/70R18
SAFETY
STAR Safety System: 4 Wheel ABS w/
Electronic Brake-force Distribution
(EBD), Brake Assist, and Vehicle
Stability Control with Traction Control
(VSC+TRAC)
Dr & Fr Pass Advanced Airbag System
Dr & Fr Pass Seat Side Airbags
Dr & Fr Pass Knee Airbags
Roll-Sensing Curtain Airbags (RSCA)
Dr & Fr Pass 3pt Seatbelts
w/Pretensioners & Force Limiters
Tire Pressure Monitoring System
EXTERIOR
Double-Walled Bed w/Tailgate Assist
INTERIOR
40/20/40 Front Bench Seat w/8-way Dr &
4-Way Fr Pass Adj, Center 3pt Seatbelts
Dual Zone Climate Control w/Sync Mode
AM/FM/MP3/CD w/6 Speakers & Aux Input
Tilt Steering Wheel
Power Windows/Door Locks/Mirrors
Cloth Trimmed Seats
Remote Keyless Entry System
Variable Intermittent Windshield Wipers
Manual Headlamp Adjust
50 State Emissions .........................
Cold Weather Package: ......................
Heavy Duty Battery, Heavy Duty Starter, ....
Windshield Wiper De-Icer with Timer, Front .
and Rear Mudguards .........................
JBL AM/FM/MP3 6-Disc Changer, ..............
12 Speakers Including Subwoofer, ...........
Bluetooth, Steering Wheel Audio Controls, ..
Integrated Satellite Radio w/3 Month Free ..
Subscription to XM Satellite Radio, ........
Aux/USB Input ..............................
18" Alloy Wheels ...........................
with P275/65R18 Tires ......................
Power Heated Outside Mirrors ...............
Running Boards .............................
Fog Lamps ..................................
Back-Up Camera Display .....................
In Multifunction Autodimming Rearview ......
Mirror: Compass and HomeLink Universal .....
Transceiver ................................
Cloth Bucket Seats with Power ..............
8-way Adjustable Driver-Side and 4 Way .....
Manually Adjustable Passenger Side, ........
Adjustable Headrests, Tilt/Telescoping .....
Steering Wheel, Center Console Shift .......
Lever, Center Console with Laptop and File .
Storage ....................................
SR5 Package: ...............................
Increases Max Tow Capacity to 10,400 lbs. ..
1,665 lbs. Payload Capacity. Hitch ........
Receiver, Supplemental Transmission ........
Cooler, Tow/Haul Mode, 4.30 Rear ...........
Differential with 10.5" Ring Gear, 150A ....
Alternator, Transmission Temperature .......
Gauge, 7 Pin Connector, Trailer Brake ......
Controller Prewire, SR5 Badging ............
Carpet Floor Mats w/Door Sill Protector ....
MSRP $35,706.00
TS members: $30,931 after $2K rebate or use the 0% apr in lieu of the rebate.
Call me at 310 939 7801 or 949 689 0717
for this Tundraaaaaaaaaaaaaaaah!
Dianne
